Activity Forums Adobe Encore DVD Encore BluRay MPEG2
  • Encore BluRay MPEG2
    Posted by Silvan Haselbach on November 23, 2009 at 10:15 pm
    I encoded a MPEG2-HD file for BluRay with Soerensen squeeze.
    mediainfo shows:
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@High
    Format settings, Matrix : üblich
    Duration : 1h 40min
    Bit rate mode : variabel
    Bit rate : 22,9 Mbps
    Nominal bit rate : 30,0 Mbps
    Width : 1 920 Pixel
    Height : 1 080 Pixel
    Display aspect ratio : 16:9
    Frame rate : 25,000 FPS
    Colorimetry : 4:2:0
    Scan type : Interlaced
    Scan order : oberes Feld zuerst
    Bits/(Pixel*Frame) : 0.442
    Stream size : 16,0 GiB (96%)
    adobe encore wants to transcode it again.
    there is no option for not transcoding.
    the transcoded file (of encore) have the same media-info data, only an other bitrate.
    where can I configure encore, that it doesn’t transcode the file again.
    thanks for help and understanding my bad english 😉
    Andrew Ford replied 16 years, 7 months ago 2 Members · 1 Reply
  • Andrew Ford
    January 29, 2010 at 5:04 am
    You also had this same problem using Compresser’s Blu-ray settings. It seemed that Encore, at the time, didn’t like anyone else’s compression. Calls to Adobe seemed to hint at this, although that was a while ago.
    Anyway, why are you doing Blu-ray in .mpeg2. You should be using h.264. Mpeg2 is only an option in Encore to support the very first, and now archaic, players. h.264 is where its at!
    Always design with a purpose.
