Activity › Forums › Adobe Encore DVD › Encore Blu-ray issues: importing as timeline
Posted by Jason Stearns on March 10, 2009 at 5:07 pmI am trying to import an m2v and ac3 files as a timeline in adobe encore cs4. Each each time I have tried, the program crashes. I used compressor to create these files which came from FCP. Is there a workaround?
Walter Biscardi replied 17 years, 5 months ago 5 Members · 5 Replies -
Joe Bowden
March 10, 2009 at 8:19 pmMaybe try importing them as assets, then create a timeline and drop them in?
Stuart Baker
March 11, 2009 at 4:28 amI imagine that Encore isn’t too happy with media files that are proprietary to Apple. I would suggest exporting out of FCP or Compressor AVI files instead of .M2V Then let Encore transocde the media into Encore compliant files.
You can export the audio separately from the AVIs, or create AVIs with audio, and allow Encore to create the elementary streams.
Andrew Ford
March 11, 2009 at 6:56 pmI find Encore CS4 doesn’t like files encoded from Compressor. Last Fall, I spoke to an “engineer” at Adobe and he asked me to tell him step-by-step what I did in compressor and the settings used to make the .m2v. Afterwards, he said those steps were correct and was unsure why it wasn’t working. Most of the time, when you bring in an .m2v from Compressor, you will see in the Project window under “Blu-ray transcode status” that the file is being read as “Untranscoded.” The “transcode settings” window never seems to offer an option to leave the file alone when it is a Compressor .m2v. Maybe I am missing something as to why it’s not working with the above workflow, but there are plenty of other ways to do this so I haven’t spent more time figuring out why.
Any movies I compress for Blu-ray with other software (like Sorenson Squeeze) work fine when imported into Encore. I like Sorenson anyway compared to Compressor because I have more control over more options.
One option if you don’t have additional compression software is to let Encore do the transcoding. I’ve let Encore do this with various source material (such as mographs out of AE with animation codec, or raw footage right off the Sony XDCAM HD) with either mpeg-2 or h.264 compression, and it’s worked pretty well on high quality settings.
Walter Biscardi
April 12, 2009 at 11:33 am[jason stearns] “m trying to import an m2v and ac3 files as a timeline in adobe encore cs4. Each each time I have tried, the program crashes. I used compressor to create these files which came from FCP. Is there a workaround?”
Did you use the correct BluRay settings in Compressor? We only use Compressor for all our BluRay MPEG-2 and AC-3 files and have had zero issues with the files in Encore CS3, CS4 and even NetBlender’s DoStudio.
The files look pretty much like their HD originals. Actual authoring in Encore is our issue, but the files themselves from Apple and Compressor are a non-issue, at least they haven’t been an issue here for the almost 2 years we’ve been doing BluRay discs.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
