Activity › Forums › Adobe Encore DVD › Encore Blu-ray authoring.
  • Encore Blu-ray authoring.
    Posted by Dima Hohlovskiy on September 29, 2010 at 7:06 am
    Hello. I’d really appreciate if someone could advise on the following issue.
    I burned a disk using direct output from Encore. I used Verbatim 25GB 6x. It’s very simple menu and some chapters. I used mpeg2 720p files. Chose “All regions”. It plays in the burner on my PC, but not in the player – says “disc error”. It’s an LG BH200 player.
    Any ideas what could go wrong?
    Thank you in advance. Any input would be appreciated.
    P.S. Could it have to do anything with 720p>1080p upscaling, that some players (including this one) have? Just a thought.
    Dima Hohlovskiy replied 15 years, 12 months ago 3 Members · 8 Replies
  • 8 Replies
  • Eric Pautsch
    September 29, 2010 at 1:04 pm
    Its possible that player wont play BD-R discs. Its the BD/HD DVD hybrid correct? how old is it?
  • Dima Hohlovskiy
    September 29, 2010 at 6:11 pm
    Yes, it is BD/HD DVD hybrid and I have it for about 1,5 years. I saw some people say that it won’t play homemade Blu-rays, but us there really no way? Thank you.
  • Daniel Ludwig
    September 29, 2010 at 7:01 pm
    hi dima,
    which frame-rate have you used and where are you located?
    cheers
    danny
  • Dima Hohlovskiy
    September 29, 2010 at 7:07 pm
    Hello, Daniel. The files are 24fps and I’m located in US.
  • Daniel Ludwig
    September 29, 2010 at 8:05 pm
    hi dima,
    720p24 is not BD-spec!
    BD-spec is:
    1080p23.98, 1080p24, 1080i60, (1080i50)
    720p60, (720p50)
    (576i25)
    480i
    NOTE: 25fps/50fps is only mandatory for BD-players that are distributed within coutries that broadcast in 25i or 50i/p like europe and ausi. they wont work in US and the rest of the world.
    the most easy way would be to upscale to 1080p24 and start over
    cheers
    danny
  • Dima Hohlovskiy
    September 29, 2010 at 10:11 pm
    Thank you very much, Daniel. I’ll try that. Wouldn’t even think it could be an issue, since I used HDTV 720p 24fps preset in Media Encoder without modifying it.
    Can I use the same AE project and just change settings in Media Encoder, or do I have to modify the project?
    Thanks again, very helpful, hope it works.
  • Daniel Ludwig
    September 30, 2010 at 6:07 am
    hi dima,
    I´m not familiar with AE, but I know you can create/duplicate your project and change your AE project-settings.
    AE is doing a really good job on upscaling, I would do this in AE instead of the media encoder.
    oh, another issue:
    all encore prior CS5 will only accept 1080p23.98 and NO 1080p24, so if you have CS5 you wont have a problem, if not, you need to change your project-setting to 1080p23.98.
    cheers
    danny
  • Dima Hohlovskiy
    September 30, 2010 at 6:18 am
    Thank you very much Danny. That’s plenty of information to work with. Will do my best. Very, very helpful.
