Activity Forums Adobe Encore DVD Encore basic codecs?
  • Encore basic codecs?
    Posted by Peter Robins on December 6, 2006 at 1:01 am
    I get a common error message ‘no decoder available for this stream type’.
    It does not stop me finishing my DVD burning process, and the finished disc(s) work fine, but I do have to do a Ctrl Alt Del to exit Encore afterwards, as the error message will not go away on ‘OK’.
    Is this a codec issue?
    I’ve already run a repair/reinstall from the original disc, but to no avail.
    It also means my transcoded files are not automatically removed after burning, so I have to do it manually.
    2nd question: How do I use an image file to burn multiple copies of a DVD. (I have compiled a small seminar DVD, but need a few copies)
    I realise I must be suffering a carbon-based error, but last time I tried, all I succeeded in burning was a copy of the image file.
    Any ideas?
    Peter Robins replied 19 years, 9 months ago 2 Members · 3 Replies
  • Butch Mcdonald
    December 7, 2006 at 12:42 am
    Hi, I have had similar problems and am currently researching in spare time to sort them out. As for the burning… after creating an ISO file to my hard drive I use IMGBURN which is free off the net and I find it very stable. I do it this way because I have had a few problems using Encore to complete the burn.
    Cheers
    Helping others gives you good cowma.
  • Butch Mcdonald
    December 7, 2006 at 12:56 am
    here’s a link that may help
    https://www.adobe.com/support/techdocs/329502.html
  • Peter Robins
    December 7, 2006 at 2:03 am
    Thanks very much Butch, much appreciated!
