Activity Forums Adobe Encore DVD Encore adds 10 seconds to timelines
  • Encore adds 10 seconds to timelines
    Posted by Webdog on August 23, 2005 at 4:28 am
    Hi all,
    The DVD I’m working on has a selection of wav files that are played against a still image.
    It’s essensially a small media player of sorts.
    Now that works out fine and all.
    Prototypes have come back with the resports that the ends of the tracks have a too large a gap of no sound.
    This was thought to be the case of having the video timeline extended over the sound in order to compensate for DVD read / searching – but a closer look reveals that all of the timelines have a duration of 42 seconds – regardless of content.
    Most of the sound clips are around 30 seconds and end at that point – so why is Encore adding an extra 10 seconds?
    -WebDog
    Webdog replied 21 years, 1 month ago 1 Member · 2 Replies
  • Webdog
    August 23, 2005 at 4:38 am
    Found the reason for this.
    If you are in the case where you have a sound file playing against a still or video image and you are placing both elements in seperately you may find that when dragging in the still image you get a dialouge box asking for the duration of the image…
    I’ve just discovered that this acts a bit too strongly and that duration set will remain regardless if you change the elements in that timeline.
    The fix that I know of is to scrap the offending timelines and re-do them again.
  • Webdog
    August 23, 2005 at 4:40 am
    Alernate solution to prevent re-linking things – is to simply delete the video layer and replace the image, and then set the duration.
