Activity Forums Adobe Encore DVD Encore 2 insists on transcoding my MPEG2 source files… HELP
  • Encore 2 insists on transcoding my MPEG2 source files… HELP
    Posted by Dylan Reeve on December 20, 2007 at 4:12 am
    I have a large DVD project that includes over 70 individual source files. They are all MPEG2 720×576 25fps at 4500kps VBR. They’ve been compressed in Apple Compressor 2.
    I can’t see anything obviously wrong with them, but Encore insists they need to be transcoded. Given they are already at a lowly 4.5mbit, I don’t want to risk another encode with them, and I don’t really want to wait the approximately forever that Encore is going to take to do the encode.
    Please help – what about my MPEG files might be making Encore unhappy, and how can I go about fixing it (preferably without having to reencode all 70-odd videos). I have FFMpeg, which I’m fairly sure can help me wrangle file containers and the like, if need be, but I have to figure out what command line options to use and even what it is I am needing to achieve.
    AVIcodec reports the following on one of these files (a reasonable sample one):
    Video : 232 MB, 4675 Kbps, 25.0 fps, 720*576 (5:4), = MainConcept (Adobe2) MPEG Video, Supported
    Audio : 19.13 MB, 384 Kbps, 48000 Hz, 2 channels, 0x50 = Mpeg-1 audio Layer 2 (MP2), , , Supported
    Kevin Monahan replied 18 years, 5 months ago 5 Members · 16 Replies
  • 16 Replies
  • Jeff Bellune
    December 21, 2007 at 3:22 am
    Are they muxed .mpg files or elementary streams? If muxed, what is the format/codec used for the audio?
    If Encore has to transcode the audio in a muxed .mpg file, then I think it has to re-transcode the video as well. (This may be incorrect, or have exceptions)
    Try exporting from Apple Compressor as elementary streams (if you haven’t done that already).
    Encore sometimes balks at elementary mpeg2 video streams if, for example, they were transcoded with open GOPs and/or frame-based encoding instead of field-based.
    Try experimenting with short excerpts from your video content so that you can see what combo of settings will work, without having to wait approximately forever.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Chuck Rosenecker
    February 8, 2008 at 9:06 pm
    We encounterd a similar problem on a project, exporting MPEG-2
    files as well as H.264 from Compressor in FCP.
    The belief is that Encore will transcode any file with frame rates outside native specs. (30p for instance)
    This proved very frustrating, but seems a simple answer looking back.
  • Kevin Monahan
    March 11, 2008 at 5:59 pm
    I have been trying to figure out what exactly are “Native Specs” for BluRay on Encore?
    I tried bringing in a standard 60i HDV (MPEG2) MOV file that I can build as an HD DVD
    file in DVD Studio Pro without transcoding but Encore insists on transcoding. This should
    be a pretty vanilla standard BluRay ready file.
  • Joe Bowden
    March 11, 2008 at 6:42 pm
    HD DVD and Blu-ray requirements are not exactly alike.
    If Encore is transcoding your video, then it’s not Blu-ray legal. Check Encore’s help for more information on Blu-ray legal frame sizes/rates.
  • Kevin Monahan
    March 11, 2008 at 7:25 pm
    As I mentioned previously, I have a very standard MPEG 2 1920/1080 60i
    M2V file. I also have 1440/1080 60i files all are under 25Mbs. These are legal
    frame rates and sizes.
    I have checked Encore’s Help options and have only found info on supported files formats
    that can be imported into Encore which then must be transcoded. I have not found info on transcoding files prior to bringing them into Encore which is what I prefer to do.
  • Joe Bowden
    March 11, 2008 at 7:42 pm
    Well, if it’s a Blu-ray legal video format, then something else is causing Encore to transcode it. Two guesses at a solution come immediately to mind:
    1. There is audio in this MOV file, and Encore is transcoding only the audio. Try stripping out the streams and then importing these into Encore.
    2. The fact that it’s in an MOV wrapper causes Encore to use its QuickTime handling code, and it’s essentially being transcoded because it’s a MOV file. I don’t have a lot of confidence that this is what’s happening, but if it is, the solution is the same as the first guess.
    I’m not totally convinced your video is Blu-ray legal. What’s its bit rate? And it’s 1920×1080 at 60i? Not 59.97?
  • Joe Bowden
    March 11, 2008 at 8:05 pm
    Also note that HDV is supported natively in HD DVD, but is not supported in Blu-ray, and would need to be transcoded. I remember that tidbit of information from a ways back.
    You might want to do a web search on this and see what you can glean from it.
  • Kevin Monahan
    March 11, 2008 at 8:10 pm
    That would explain it. I went ahead a built a DVD image but I don’t see any way to test
    the file on a mac without burning the disc since the DVD Player app does not recognize the
    BluRay files. Are there any software DVD player apps for playing a blu-ray image off
    of a hard drive?
  • Joe Bowden
    March 11, 2008 at 8:18 pm
    If you built a DVD image, then Encore should have transcoded all your HD video to SD, and create a standard DVD-Video image file. Or did you create a BD image file?
    If it’s BD, then you’ll need a software player that supports Blu-ray (Apple’s DVD Player does not). Try vlc, maybe? Anything else would probably be retail software, and I don’t imagine there are many choices on the Mac yet.
  • Kevin Monahan
    March 11, 2008 at 8:39 pm
    I’m sorry, I meant BD. I am only using Encore for Blu-Ray. I realize that the Apple DVD player
    does not support BD and am looking for a Mac software player that does, but I don’t see one. We are creating HD DVD images that work fine off of USB Flash devices with the Apple DVD Player and are wantng to do the same type of thing with Blu-Ray
