Activity Forums Adobe Encore DVD encore 1.5 crashes when combining AC3 audio with m2v video
  • encore 1.5 crashes when combining AC3 audio with m2v video
    Posted by Pom on August 11, 2005 at 12:23 pm
    I have rendered a trailer with Pinnacles Liquid edition.
    I render it as m2v with 5.1 surround sound.
    I want to produce the dvd with encore but it crashes when I combine the audio with the video.
    It says “an abnormal condition has been detected…” After a new “unidentified error” sign comes up and I I have to ctrl-alt-del and close encore cause it has stopped answering…?
    There’s no trouble importing the files and nothing strange about making a new timeline with the m2v-file or the ac3 file but when combining them makes encore crash?
    Anyone know why encore does this?
    /Petri
    Pom replied 21 years ago 2 Members · 6 Replies
  • Joe Bowden
    August 11, 2005 at 4:36 pm
    Normally, it doesn’t do this.
    Can you give me some details about the AC3 file? In what application was it made, bit rate and other settings?
  • Pom
    August 11, 2005 at 5:48 pm
    I’ve rendered the project with Pinnacle Liquid Edition 6.1
    I have no problem listening to the audio if I have tha AC3 file alone in a timeline.
    The bitrate of the ac3 file is 384000 Bits/second 48000 Hz.
    I rendered the same project with uncompressed audio file and imported those files to Encore. I had no problem combining the audio with the video then. But as I was building the project encore prompted the same error messages just as it started to write the files…?
    Encore crashed but it continued to write the files and I got a DVD image file completed anyway.
    Very strange if you ask me.
    Petri
  • Joe Bowden
    August 11, 2005 at 8:24 pm
    Sounds like some other AC3 decoder may be clashing with Encore’s.
  • Pom
    August 12, 2005 at 12:41 pm
    Do you have any idea why encore crashes when I have the uncompressed audio file? And only in the end when I have started building the disk.
    It has been doing this for quite some time now.
    Best regards
    Petri
  • Joe Bowden
    August 13, 2005 at 12:43 am
    Since it crashes when transcoding to AC3, I really think it’s somehow related to Liquid Edition’s AC3 encoder/decoder, or another AC3 encoder/decoder on your system.
    You may be able to confirm this by importing a WAV file (no AC3) and changing your project encoder settings to PCM or MPEG-1 Layer II, and then see if it finishes building without error.
  • Pom
    August 13, 2005 at 2:07 pm
    In the last test yesterday I had rendered the project with uncompresesd pcm audio but encore still crashed just as it had started to write the files. I got the dvd built cause encore continued in the background of the error messages.
    What’s the easiest way to get ac3 audio if I render uncompressed audio with Liquid edition?
    Petri
