Encoding…”invalid framesize/framerate for this level”
Hello there,
I’m rather new to Premiere and I am trying to export a video that I created for a contest. It needs to be output at the following specifications:
MPEG4 (Divx, Xvid) format
320 x 240 resolution
MP3 audio
30 frames per second
I can get the MPEG4, the size, and the audio right…but when I change the fps for output to 30 (from 15, at which it is already set), it says “Invalid framesize/framerate for this level. Please lower the Frame Dimensions, Frame Rate, or increase the Profile and Level and try again”. I can’t change the dimensions or rate, since they are required for the contest…and I have no idea what it means by Profile and Level. Please help! Thanks so much,
Maddy
