Activity Forums DVD Authoring Encoding with Procoder problem – darker image
  • Encoding with Procoder problem – darker image
    Posted by Michal Jaworski on September 15, 2011 at 9:39 pm
    I use Premiere to edit my footage shot in DV Pal. Then I export it using procoder to mpeg2 and author it on DVD. But here is problem, exported, encoded movie is a bit darker when i watch it on CRT TV.
    I tried encoding same footage in Nero Vision and i think it was closer to original footage then one from procoder.
    What’s the cause of this? Is there any filter i can use or do i set something wrong in procoder?
    to summarize:
    Footage shot in DV Pal -> edited with Premiere -> encoded with Procoder -> good quality but a lot darker then original footage
    Footage shot in DV Pal -> edited with Premiere -> encoded with Nero Vision -> poor quality but same brightness as original footage
    Michal Jaworski replied 14 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
