Activity › Forums › Adobe Premiere Pro › Encoding to stereo to mono drops volume, why?
  • Encoding to stereo to mono drops volume, why?
    Posted by Shayne Weyker on November 2, 2007 at 4:47 pm
    I’m encoding a bunch of videos (shot on 32Khz DV) where the same dialogue is on the left and right track but at different levels, these are a stereo pair in the 32khz DV project. Rather than manually EQ the timelines I decided to encode a bunch videos to mono.
    The original audio source was two wired lav mics right next to each other, one going to L on the deck one to R.
    But I’ve found that when encoding that I lose a lot of volume in the final encoded file making it quieter.
    I’m not sure but I think that raising the levels on the timeline even a lot doesn’t seem to change the encoded output’s audio noticeably
    the output format from CS3 PPPro Media Encoder is a cusomized version of “Ipod, Large”
    .mp4
    h.264 baseline
    640×480
    32khz/128kbit aac audio
    ipod compatible
    Can anyone tell be the quick and easy way to get (at least though the encoder) L/R balanced and adequately loud audio when starting from audio that leans a bit right or left?
    Thanks for any help.
    Shayne Weyker
    https://weykervideo.com
    –Shayne Weyker
    Vince Becquiot replied 18 years, 11 months ago 2 Members · 1 Reply
  • Vince Becquiot
    November 2, 2007 at 5:50 pm
    Shayne,
    I don’t know how the Ipod export handles stereo tracks, I would assume it just mixes down the channels involved to mono, but apparently that was not the case.
    What I can offer you is the right workflow for your next edit 🙂
    Before you drop anything on the timeline (otherwise those option won’t be available to you), select all the clip the are recorded on separate channels, go to Clip > Audio Options:
    Then you can do either of these things:
    Break out to mono will give you separate mono channels in the project window itself.
    Or even better: Source channel mapping, and change that to mono. That will give you 2 separate mono channels on the timeline, so that you can pick the appropriate one if the other peaks.
    Cheers,
    Vince
