Activity Forums Adobe Media Encoder encoding to MPEG2 with PCM 24bit audio
  • encoding to MPEG2 with PCM 24bit audio
    Posted by Tom Smith on May 25, 2013 at 12:31 pm
    Hello!
    I have some requirements from a tv station and can not manage to find the right settings in adobe media encoder.I am mainly failing to find PCM 24bit audio with the MPEG2 Encoder.
    The required settings are the following:
    – Video:
    HD (XDCAM HD422 1080i25 compatible): MPEG 2, 50 Mbit/s, constant bitrate,
    1920×1080 25i (4:2:2 PROFILE@HIGH LEVEL),
    containerformat .mpg, .mxf or .mov
    – Audio:
    linear PCM, 24 Bit / 48 kHz. ,stereo
    Maybe someone can help me out a bit.. I would very much appreciate it!
    Kris Merkel replied 13 years, 3 months ago 2 Members · 1 Reply
  • Kris Merkel
    May 29, 2013 at 1:22 pm
    As you have probably seen from the Forums on Adobes site that this is not possible with AME. You will have to use Episode or Compressor if you have it.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
