Activity Forums Apple Final Cut Pro Legacy Encoding to Mpeg 2 = Lightening Picture
  • Encoding to Mpeg 2 = Lightening Picture
    Posted by Dave Martin on June 18, 2006 at 8:16 pm
    Hi Again Guys
    Long time editor…first time Mac Guy here…
    When I encode my video to Mpeg 2 through Compressor…it seems to lighten my picture (almost like it’s adding setup – 7.5 IRE) Anyone else run into this and what’s the best way to combat it?
    Thanks so much for replies…
    Tim Martin
    -MacBook Pro – 2.16GHz Intel Core Duo – 2 gig Ram
    -FCP Studio 5.1.1 – QT 7.1 – OSX 10.4.6 – Lacie D2 dv external drive – G-raid dv drive
    Dave Martin replied 20 years, 2 months ago 2 Members · 3 Replies
  • Dave Martin
    June 19, 2006 at 3:56 pm
    No one run into this?
    Could there be a setting somewhere…or apply a filter?
    Tim Martin
  • Accountneedsrealnameupdate
    June 20, 2006 at 7:06 pm
    What codec is your source? There is a known problem with quicktime’s RGB to YUV conversion, we had the same problem when trying to compress animation codec files, switching to the decklink 10bit codec fixed it, I’m sure the apple uncompressed 10bit would work too.
    Glenn Stewart
    1k Studios
  • Dave Martin
    June 20, 2006 at 7:14 pm
    Hi Glen
    I’m strictly using the basic dv25 codec from dv cam into fcp – edit and then encode…can’t find anything except possible using filters to compensate (which is not appropriate in my opinion)
    Thanks so much for the reply…
    Tim Martin
