Activity › Forums › Adobe Encore DVD › Encoding Shortens Video
Posted by Michael Brown on January 14, 2008 at 4:56 pmRunning CS3
I have a short credit list that runs about 30 seconds. The MPEG was created by Sorenson 4.5. Encore wants to transcode this video – it usually doesn’t transcode these files.
After transcoding, the video is now about 24 seconds; the sound track remains 30 seconds. Not a good thing.
Check project reveals “trims and/or chapters adjusted”
I appreciate any advice.Mike Brown
Video/Film Producer
American Heart AssociationTodd Smaretsky replied 16 years, 11 months ago 3 Members · 8 Replies -
Jeff Bellune
January 14, 2008 at 5:49 pmFrame rate of source video?
Closed GOPs selected in encoding parameters in Squeeze?
Please list your other encoding parameters, both audio and video.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Michael Brown
January 14, 2008 at 6:23 pmHi Jeff!
MPEG 2 Elementary; 2-pass VBR
MAX: 7812 AVG: 5859 MIN: 3735
720 X 480 NTSC UNCONSTRAINED
29.97, 4:3, LOWER FIELD
I FRAMES: 15; P FRAMES: 3; AUTO GOP: NONE (other options are “fast” & “vcsd”)
Audio is just an ordinary 48k/16 .wav file exported from the Avid.
I may try a 1-pass CBR to see if that fixes things.
Thanks for your fast reply.
Mike -
Jeff Bellune
January 14, 2008 at 6:41 pm[Michael D. Brown] “The MPEG was created by Sorenson 4.5. Encore wants to transcode this video – it usually doesn’t transcode these files.”
This is the statement that concerns me the most.
Did you start with one of the DVD presets in Squeeze?
There is a checkbox next to the “Auto GOP” drop-down box. It forces Squeeze to close the GOPs, which is better for use in Encore. Is that box checked?
Are you saying your source audio is 48KHz/16-bit, or that you exported from Squeeze as MPEG PCM audio? Squeeze’s default (as you are probably aware) is to transcode the audio to MPEG Layer 2 audio, which is often a very bad choice for DVD.
Are you accidentally multiplexing the audio and video streams? If Encore gets a muxed program stream with audio that is not matched to the project audio settings, it will re-transcode the whole muxed file, audio *and* video.
-Jeff
Michael Brown
January 14, 2008 at 9:04 pmDid you start with one of the DVD presets in Squeeze?
MB: Yes. It is a preset.There is a checkbox next to the “Auto GOP” drop-down box.
MB: no checkbox… just the options “none/fast/vcsd.”Are you saying your source audio is 48KHz/16-bit, or that you exported from Squeeze as MPEG PCM audio?
MB: No. The .wav file is exported directly from Avid.Squeeze’s default (as you are probably aware) is to transcode the audio to MPEG Layer 2 audio, which is often a very bad choice for DVD.
MB: Squeeze doesn’t touch the audio. Whatever Encore is doing, it affects only the video. The audio asset comes in as “Transcoded.”Are you accidentally multiplexing the audio and video streams?
MB: No, I looked at that… “DVD MPEG 2” format; elementary stream.
Thanks for the ideas. –MB -
Michael Brown
January 14, 2008 at 9:23 pmI was using a QT reference for Sorenson as I’ve always done before. This last time, I made a plain old QT movie – not a reference – for Sorenson to crunch. Encore seems happy with the result so I’m moving on. May be something weird with the original media. Always blame the Avid…
–Mike -
Jeff Bellune
January 14, 2008 at 10:56 pm -
Todd Smaretsky
September 22, 2009 at 8:15 amI have no idea if you still need help but I was having the same problem. You WANT to keep quicktime Reference because it is uncompressed. You don’t want to encode it TWICE.
So, I was having the same problem after I encode then I import into Encore and it was doing the same thing. i would have to encode it again. The problem is – at the top where it says formats. Pull down that menu and select mpeg 2 DVD R – The R is the important thing. By default it is just mpeg DVD – you want mpeg DVDR.
Hope this helps.
Todd
