Activity › Forums › Compression Techniques › Encoding service?
Encoding service?
Posted by David Taylor on August 2, 2018 at 6:47 pmI have a friend that’s still editing a show on FCP6 (MacOs Sierra) and needs to output a MXF file for broadcast. We’ve had a little luck using the old Sony Content Browser(2.3.4) export with some workarounds (it only encodes half of your program).
I was wondering if there was an encoding service he could just upload a Quicktime Prores file to and get back the format he needs for the media outlet.
DT Motion Pictures
https://www.davetaylormp.comCraig Seeman replied 8 years, 1 month ago 2 Members · 11 Replies -
Craig Seeman
August 2, 2018 at 8:08 pmDo you know anyone with High Sierra or might you be willing to partition a drive?
The current version of Apple Compressor and encode to ProRes MXF, AVC Intra MXF, XDCAM HD MXF.
Compressor is $50 and the OS is free of course. -
David Taylor
August 2, 2018 at 8:21 pmHmm… that’s worth a shot.
I assume you can use Compressor as a stand alone program?
How robust is the new closed caption feature? He just bought MacCaption to do that.
Thanks.
DT Motion Pictures
https://www.davetaylormp.com -
Craig Seeman
August 2, 2018 at 8:41 pm[David Taylor] “I assume you can use Compressor as a stand alone program?”
Absolutely. You can export a ProRes file from FCP6 and move that file over to Compressor (on High Sierra).
[David Taylor] “How robust is the new closed caption feature?”
In Compressor? I haven’t tried it yet.[David Taylor] “He just bought MacCaption to do that.”
Telestream has Flip but that’s a monthly service. If you can buy it just for one month that might be a solution and it should work with Mac Caption generated captions.
David Taylor
August 17, 2018 at 2:36 pmHere are the specs that Fox wants.
It appears Apple Compressor cannot encode at 59.94 only 29.97.
We tried Telestream’s Switch, could not do drop frame.
Any other ideas?
DT Motion Pictures
Craig Seeman
August 17, 2018 at 3:39 pmI’m not sure what you’re looking at but Compressor absolutely supports interlaced video.
Don’t confuse Frames with Fields. The only time 59.94 frames is used in broadcast is for 720p (as in progressive only)
Otherwise all broadcast is 1080i59.94 which is 29.97 frames per second. -
David Taylor
August 17, 2018 at 6:13 pmI don’t think interlacing is the issue. We are just trying to get a file that will pass the auto QC test by the Fox system computer. The video we encoded using Switch passed every item in the specs EXCEPT drop frame. Which seems odd to me since I thought just being 59.94 fps qualified as drop frame, but I’m not an engineer.
DT Motion Pictures
Craig Seeman
August 17, 2018 at 6:19 pm[David Taylor] “I thought just being 59.94 fps qualified as drop frame”
Drop Frame is a form of time code. 59.94 can be either Drop or Non Drop time code.
David Taylor
August 17, 2018 at 6:58 pmWe’re just trying to get a file that will pass the system check with these specs:
MXF (OP-1a)# Audio Channels
>= 8Resolution
1280x720Drop Frame
YesBit Rate
>= 50 MbpsFrame Rate
59.940 fps
DT Motion Pictures
Craig Seeman
August 17, 2018 at 9:00 pm -
David Taylor
August 24, 2018 at 4:00 pmJust an update on this to mark it SOLVED.
My friend was able to finally able to get a file to pass the system check that he compressed with Apple Compressor. According to him, you need to set the timecode, then you have an option to check the box for “drop frame.”
Craig, thanks for your help with this.
DT Motion Pictures
