Activity › Forums › Compression Techniques › Encoding PAL for DVD using Apple Compressor
  • Encoding PAL for DVD using Apple Compressor
    Posted by Sean Kapleton on November 14, 2007 at 9:09 pm
    Hello
    I am looking to get some advice on encoding footage from a PAL BETACAM SP tape (from an Avid Adrenaline) – ultimately to then encode using Compressor for DVD (both NTSC & PAL format)
    I need to compress for DVD in PAL & NTSC and again the footage is from a 90 minute BETACAM SP tape onto the Avid Adrenaline. I have only ever done NTSC so this fottage with be in PAL when i bring it into Compressor.
    The Senior editor has a pretty busy schedule during the day but is ok with me doing this personal project after hours – I just want to make sure i set it all up properly.
    I have never done anything PAL or BETASP on this deck and Avid Adrenaline so I am hoping you guys can tell me everything I need to know about setting up Compressor to encode both a PAL and NTSC set of MPEG2 & AAC.
    Any help would be greatly appreciated. Thank you
    BKYLN
    Sean Kapleton replied 18 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
