Activity Forums Apple Final Cut Pro Legacy Encoding issue
  • Posted by Shyfty on July 30, 2007 at 3:07 am
    I am trying to encode some video and I keep getting the error “Inconsistent Audio Sample Rate”. Not sure what I did to cause this. Anyway to fix this error?
    Tom Wolsky replied 19 years, 1 month ago 2 Members · 3 Replies
  • Tom Wolsky
    July 30, 2007 at 3:17 am
    When you say encode, are you trying to capture? DV material? Sounds like you might be using the default 48K preset while you’re material is recorded at 32K. If so you need to make capture and sequence presets for 32K.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Shyfty
    July 30, 2007 at 5:56 am
    I am trying to encode/compress the final product to WMV specifically… Everything was working fine until…well I am not sure, but now I keep getting the same error message.
    “inconsistent audio sample rate”
  • Tom Wolsky
    July 30, 2007 at 7:53 am
    Are you using Flip4Mac? Is this OS 10.4.10 and QuickTime 7.2? Go to the Flip4Mac web site. There is problem with this set-up. I believe they have a workaround there.
    All the best,
    Tom
