Activity › Forums › Compression Techniques › Encoding HDV Mpeg 2
  • Encoding HDV Mpeg 2
    Posted by Jason Rodriguez on August 14, 2005 at 9:49 pm
    I am having some trouble encoding an HDV film I shoot. I have edited in FCP5 and have tried using compressor, bitvice, and quicktime on reference and self contained quicktime movies. I seem to be getting the same results of…I guess you would call it banding…artifacts. Does anyone have any suggestions or recommended settings that would give me better results? I am a little bummed because the footage looks so great.
    Jason
    Specs
    Video shot on Sony Z1 at NTSC 60i 1080
    Edited in FCP5 HDV native
    CPU is G5 dual 2 gig 2gb ram
    encoders tried Compressor, QT, Bitvice all the latest versions
    Charles Simonson replied 21 years, 1 month ago 2 Members · 1 Reply
  • Charles Simonson
    August 14, 2005 at 10:46 pm
    I assume you are encoding for DVD because you mentioned BitVice.
    For encoding of High-Def sources, especially to a Standard-Def size, I really like the MainConcept Mac Encoder. It is very fast and the streams it produces are very reliable. Also, if you need and require the utmost control over your image, then you really should look into Compression Master 3.1. It has a new 2-pass MPEG-2 encoder that does a pretty good job, and when combined with its preprocessing and filtering capabilities, CM 3.1 shines for HD sources.
