Activity › Forums › Apple Final Cut Pro Legacy › Encoding HD video to make SD dvd?
  • Encoding HD video to make SD dvd?
    Posted by Dalebeldin on June 18, 2007 at 9:04 pm
    Help! I need to make a SD dvd of a HD project, but so far all the dvd’s made have unacceptable image streaking whenever the camera pans or tilts. I suspect that I’m not using the correct settings to output the project, right now as a Quicktime movie. Any advice will be greatly appreciated!
    The project was shot on a Sony HC-3 camera, edited in Final Cut Pro 5.0.4 on a Mac PowerBook G4 using OS X 10.4.9, using iDVD to burn the dvd
    Dale
    Chris Borjis replied 19 years, 3 months ago 4 Members · 3 Replies
  • 13 Create COW Profile Image
    13
    June 18, 2007 at 9:54 pm
    [dalebeldin] “Help! I need to make a SD dvd of a HD project, but so far all the dvd’s made have unacceptable image streaking whenever the camera pans or tilts. I suspect that I’m not using the correct settings to output the project, right now as a Quicktime movie. Any advice will be greatly appreciated!
    The project was shot on a Sony HC-3 camera, edited in Final Cut Pro 5.0.4 on a Mac PowerBook G4 using OS X 10.4.9, using iDVD to burn the dvd”
    First off this has topic has been covered a lot here on the cow, a simple search will bring up a lot of information.
    Why are you using iDVD, as a professional I would never deliver a DVD that would look like one that my 8 year old neighbor could make. Use DVD Studio Pro, iDVD gives you no control over the encoding of the video.
    Export using compressor this will give you much more control over the compression of the video. Then bring in the compressed files into DVD SP.
  • Walter Biscardi
    June 19, 2007 at 12:04 am
    [dalebeldin] ”
    Use compressor to make the MPEG-2 files and use DVD Studio Pro to author the DVD. Do not use iDVD.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Chris Borjis
    June 19, 2007 at 2:29 am
    After making a discovery that quicktime conversion export downsizes HD to SD better than compressor even with its resizing filter set to highest quality, I export an SD file that way, then drag that to compressor.
