Activity Forums Compression Techniques Encoding from 1080 Apple ProRes for a local diffusion on computer?
  • Encoding from 1080 Apple ProRes for a local diffusion on computer?
    Posted by Paul Sellis on September 10, 2012 at 12:57 pm
    I need your advises..
    I have a FinalCut Pro 7 exported file:
    1920×1080 Apple Prores HQ + 16 bit Stéréo 48,000 Khz
    I have to send it to a foreign place where it will be displayed in loop during an exhibition. I will not be present.
    It’s said that it will be played on 2 distinct places by 2 computers (not sure if all are Mac).
    I supposed that they should be played by QuickTime or VLC on both platforms.
    But I have to compress it as for 26 minutes it’s quite huge: 24Go
    Could you please tell me if there would be a better solution:
    I think to compress the original file in H264/AAC at high level quality and send the resulted file on a USB key or via a web server.
    (I could rip a BluRay DVD but I have no BluRay recorder and I’m not sure it’s easy to do it on Mac even if I have Compressor 4 to encode)
    I’ve heard here that Handbrake or Squeeze do better job with H264 than Compressor.
    With Handbrake I am around these settings:
    a 1920×1080 .mp4 file with x264 Constant Quality RF 13 and AAC (core audio) Stereo 320 @ 48
    Is that OK ?
    Thanks for your help
    Paul
    Paul Sellis replied 14 years ago 3 Members · 4 Replies
  • Paul Sellis
    September 12, 2012 at 9:48 pm
    No help…
    just to simplify my question:
    what codec and compression settings would you use to reencode an Apple ProRes video file sent by internet that would be played on computers from different platforms?
  • Eric Strand
    September 13, 2012 at 1:08 am
    PC and Mac can play back H264 so you should be safe with your settings in Handbrake.
  • Craig Seeman
    September 13, 2012 at 1:24 am
    H.264 .mp4
    Even Windows Media Player 12 plays it natively (Windows 7)
    Those on Vista or Windows XP would still need Quicktime.
  • Paul Sellis
    September 16, 2012 at 10:02 am
    Thanks a lot for your answers.
    So I have used Handbrake to encode with x264 my original 20 minutes ApplePro Res file 1920×1080 25fps
    I have used RF15 to get maximum quality and fulfill the 2Go free data transfer offered by WeTransfer
    Do you think that the quality should be OK: the result is 14Mbits
    (I could use my own server to share larger files)
    If not the other solutions could be :
    – to increase the RF ?
    But is it safe to read all day long on a computer a looping file with high bandwidth? It’s for an exhibit, and I am scare of choppy movie…
    – to encode up to 25Mbits and burn a BluRay?
    What do you think ?
