Activity › Forums › Compression Techniques › encoding for Blackberry Pearl
  • Daniel Low
    July 18, 2008 at 2:25 pm
    The following Video formats are supported:
    * MPEG-4 Part 2 – Simple Profile + bvops (including DivX files in this format)
    * H.263 Profile 0 and Profile 3
    The following Video file extensions are also supported:
    * .avi containing MPEG4 Part 2 and H.263
    * .mov containing MPEG4 Part 2 and H.263
    * .3gp containing MPEG4 Part 2 and H.263
    * .mp4 containing MPEG4 Part 2 and H.263
    * .m4v containing MPEG4 Part 2 and H.263
    * .mpg containing MPEG4 Part 2 and H.263
    MPEG-4 is obviously better than H.263
    According to Blackberry themselves these are the transcode settings:
    Video format: MPEG-4
    Video file extension: .AVI
    Resolution (4:3): 240×180
    Resolution (16:9): 240×135
    Video bitrate: 400 kbps
    Frames per second: 24
    Audio format: MP3
    Audio bitrate: 128 kbps
    Sample rate: 44 khz
    Channels: 2 (Stereo)
    I’d suggest you can at increase the bitrate and frame rate if needed.
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
