Activity Forums Apple Final Cut Pro Legacy encoding FLV through QT conversion
  • encoding FLV through QT conversion
    Posted by Michael Williams on November 5, 2009 at 4:19 am
    I recently got a new mac pro and am slowly getting everything back the way I had it on my old system. I just went to create some FLV files through QT Conversion and the FLV option is not in the pull-down. It is on my laptop system and I have an encoding profile that I use for a particular client that I brought over.
    I am unsure why FLV is available on my laptop system, but not on the new desktop system. both intel, same version of FCP, same version of QT.
    Any ideas? Do I need a plug-in that I’m not aware of?
    thanks,
    Mike
    Michael V. Williams
    producer/editor
    http://www.vernonvision.com
    Michael Williams replied 16 years, 9 months ago 3 Members · 4 Replies
  • Craig Russillroy
    November 5, 2009 at 5:46 am
    Hi micheal
    I believe the flv plugin cones with flash installation … I think it’s been a while since I installed flash – check on the laptop for apps that are not on the tower hope this helps – I use visualhub which does batch encodes and awesome flv
    MINTedit
    London, England
    Mac Pro – 8gig ram – FCS 3 – CS4 – Cinema 4D
    Film, Edit and Deliver
  • Bret Williams
    November 5, 2009 at 9:10 am
    Here’s a crazy thing. Flash now supports H.264. Just render a h.264 QuickTime, then change the .mov to .flv. Done. Works great. Looks better.
  • Craig Russillroy
    November 5, 2009 at 9:55 am
    Bret – Great Tip !!! Man alive I have been doing it old school
    MINTedit
    London, England
  • Michael Williams
    November 5, 2009 at 7:55 pm
    This is interesting. by changing the extension is the file now an FLV? or is it just emulating an FLV?
    curious.
    btw, I found the plugin on my laptop under library/quicktime. it was called “FLV.component.” not sure where it originally came from.
    thanks,
    mike
    Michael V. Williams
    producer/editor
