Activity Forums Adobe Premiere Pro Encoding Failed
  • Encoding Failed
    Posted by Jeff Goin on September 2, 2010 at 1:41 pm
    Experts,
    I’m at the end of a two-year project, a 1.7 hr training video. The authoring has been done in Encore cs4. I have rendered each of the 15 chapters then imported those onto a premiere timeline. THAT timeline was then sent to Encore where I built the menu structure and tested. It works as I want it to on the preview but when I go to burn the DVD image to file, it works for about 4 hours then says “encoding failed”.
    I’m not using the timeline except to set my markers. When I do a “check project” it complains about having an orphaned timeline but I ignore and continue. I can’t imagine that would be a problem and I don’t know what would happen if I got rid of that timeline — plus i use it to set my poster frames for the chapter buttons.
    Any ideas? I’m dead in the water right now.
    Jeff G.
    “If there’s air there, it should be flown in” – FootFlyer.com
    Jeff Goin replied 16 years ago 2 Members · 2 Replies
  • Ann Bens
    September 2, 2010 at 10:32 pm
    I would get rid of the orphan timeline.
    It means you have a timeline with no asset.
    Then try again.
    You could also render from Premiere and import into encore.
    Make menu, link assets and burn.
    I find when i change things in Encore to many time it gives errors.
    Usually i start over with already rendered assets.
    Hope this helps.
  • Jeff Goin
    September 2, 2010 at 11:52 pm
    Ann,
    OK, I’ve been trying a number of tests with a small snippet just to see the whole process through to completion even with only a minute of content. Now I have another problem: using widescreen. But I’ll make another post with that as the title.
    I’ll try your advice about rendering before importing if I can’t resolve it othwerwise. It’s being output to both blu ray and dvd so I was hoping to avoid two different versions.
    Jeff G.
