Activity Forums DVD Authoring Encoding DVD in real time from DigitalBeta
  • Encoding DVD in real time from DigitalBeta
    Posted by Siu kei Ip on March 28, 2011 at 2:45 pm
    Hi, I would like to build up a PC for encoding DVD from DigitalBetacam (NTSC/PAL). I want the quality like to be most retailed DVD. However, I am short of budget, so, which capture card should I choose?
    Siu kei Ip replied 15 years, 5 months ago 5 Members · 13 Replies
  • 13 Replies
  • Bill Stephan
    March 30, 2011 at 5:02 am
    See if you can find someone selling a used Zapex encoder board. Be aware that the company went out of business years ago, so you want at least the board and the software. Better would be a working PC with the board already set-up.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Siu kei Ip
    March 30, 2011 at 2:19 pm
    Thx for reply!
    However, are there any capture cards that have DVD encoding function??
    Like Black Magic, Canopus?
  • Bill Stephan
    March 30, 2011 at 4:53 pm
    Canopus might have an encoder board similar to Zapex. There is also the Sonic Solutions encoders. Using a Black Magic or Aja capture card requires software encoding after capture.
    Bill Stephan
    USA Studios
    New York City
  • Siu kei Ip
    March 31, 2011 at 2:25 pm
    Thx!
    I’ve checked Canopus, and find out FIRECODER Blu. IS the quality Okay for retailed DVD?
    And what is the minimum requirement of the PC for DVD encoding?
  • Bill Stephan
    March 31, 2011 at 4:38 pm
    [Siu Kei Ip] “And what is the minimum requirement of the PC for DVD encoding?”
    The manufacturer of the encoder board will have specific requirements for the PC for its products. In general, you want a workstation PC (not an “office” PC) for its segmented PCI bus. You need a faster (and big) second hard drive to store the media. DVD encoding does not require a RAID.
    [Siu Kei Ip] “IS the quality Okay for retailed DVD?”
    You should demo the encoder you are considering using familiar footage to see whether you like the results.
    Bill Stephan
    USA Studios
    New York City
  • Siu kei Ip
    April 1, 2011 at 2:38 pm
    Actually, if I decide to buy a capture card and use software encoder for DVD/Blu-ray production, will I get worse quality than hardware realtime encoding?
  • Eric Pautsch
    April 4, 2011 at 10:26 pm
    Most encoders are software based these days. Cinemcraft SP is about the finest encoder around unless youre prepared to hand over thousands of dollars
  • Siu kei Ip
    April 5, 2011 at 4:38 am
    How about capture card??
    Which one can be used to capture footage from Digibeta/HD??
  • Michael Sacci
    April 5, 2011 at 7:22 am
    Slu,
    I have an old Sonic Solution SD2000 card and a computer that can run it. My version for a Mac and it only runs on OS9. I can sell a turnkey system so it really doesn’t matter what system is it. This card has reverse telecine and segment based recoding.
    The only advantage of any hardware encoder card is if you are coming from a tape (which is what you said you where doing) You don’t capture and then encode it all happens in one step. But the card is only for encoding for DVD authoring.
    If you are interested contact me at onthecow (at) michaelangelodv (dot) com.
    Once again Hardware encoder does not give you better than software but it gives you professional quality at real time from tape masters. I will let this go cheap, I just need to replace the computer with any intel mac, a used iMac intel would be fine.
  • Jeff Pulera
    April 7, 2011 at 2:30 pm
    The Matrox MXO2 Mini offers realtime MPEG-2 capture straight to .m2v and .wav from Composite, S-video and Component sources, with RCA stereo audio input.
    I haven’t messed with this new feature enough to comment on how good the quality is using the realtime capture to MPEG-2 though. Probably not on par with a high-end specialty encoder
    Jeff Pulera
    Safe Harbor Computers
