Activity › Forums › Adobe Premiere Pro › Encoding Codecs
  • Encoding Codecs
    Posted by Hunt Armistead on May 7, 2006 at 3:50 pm
    Good Day All,
    Up until recently I’ve been semi-happily editing along using PPro 1.5 and a Canopus DVRexRT w/M2. Due to a hard disk crash and a few choice words, I’ve built a new machine, upgraded to PPro 2 and attempted to move the DVRexRT over.
    New machine works like a champ and is FAST. (Intel 930, 955 chipset, 2GB RAM, 600GB RAIDed SATA)
    I’m disappointed that it doesn’t look like Canopus will provide support for PPro 2 but…
    When I opened some PPro 1.5 projects in PPro 2.0, the Canopus codec was there (export/movie/settings/compressor) along with Cinepak, DivX Pro, Indeo, etc. And the Canopus codec ran great.
    When I open a new project, only the MS codec is available.
    Any thoughts ?
    Thanks a lot,
    Huntster
    Hunt Armistead replied 20 years, 4 months ago 2 Members · 2 Replies
  • Mike Velte
    May 8, 2006 at 11:42 am
    Premiere and most NLE’s can access any most any codec installed on a system…at least for export. To use the Canopus hardware you will need those drivers that will never come.
  • Hunt Armistead
    May 8, 2006 at 4:53 pm
    Mike,
    Yes, you’re right. I shouldn’t be able to use the Canopus hardware if the drivers aren’t installed.
    But it seems to me that I should be able to see the all the codecs regardless of which project I pull up – and that’s my point. I’m not able to see them all consistently.
    Thanks for the response.
    Hunt
