Activity › Forums › Adobe Media Encoder › ENCODING: Chroma/GOP/Pixel Aspect Ratio
Posted by Ben Komins on October 17, 2014 at 12:45 amURGENT:
Hi:
Can someone please point me in the right direction within Adobe Media Encoder for the following specs:GOP: Closed Long GOP (IBBP)
Pixel Aspect Ratio: 9:10
Chroma: 4:2:2 (HP@HL)Ben Komins replied 11 years, 10 months ago 2 Members · 6 Replies -
Ivan Myles
October 17, 2014 at 5:04 amMPEG2 codec with GOP settings:
M frames: 3
N frames: 4 for IBBPIBBPIBBP…
Closed GOP every: 4 (or possibly a multiple of 4)The other settings are marked accordingly.
Ben Komins
October 17, 2014 at 5:06 amThanks Ivan –
Just so I understand it a better – can you point to a resource that explains what you just wrote with details? -
Ivan Myles
October 17, 2014 at 5:12 amRefer to “Video Export Settings”
https://help.adobe.com/en_US/mediaencoder/cs/using/adobemediaencoder_cs5_help.pdf
Ben Komins
October 17, 2014 at 5:15 amMy apologies –
I read through that earlier – and just took a second look.What I meant is how does your 2/4 Closed 4 recommendation = IBBP (as opposed to just leaving it at the default 3/15 Automatic GOP placement?
Ivan Myles
October 17, 2014 at 5:49 amSorry, I made a mistake in the previous post. Been a while since I used MPEG2. I will edit the post shortly.
M = Number of B frames between I/P frames. For IBBP, M=3 produces a P or I-frame every third frame. The minimum is M=1, which corresponds to zero B-frames.
N = Number of frames between I frames. N=4 produces IBBPIBBPIBBP… Setting N=15 produces IBBPBBPBBPBBPBP as a group of pictures. Your spec doesn’t state GOP length. Admittedly, 4 is pretty short, and a number about half the frame rate is more common. Setting N=15 instead of a multiple of 4 (such as N=16) just changes the last frames in the group from BBP (16) to BP (15).
