Activity Forums VEGAS Pro Encoding AVCHD and MOV for Stock Video Use
  • Encoding AVCHD and MOV for Stock Video Use
    Posted by Duane Weed on April 14, 2014 at 1:24 pm
    I am using Vegas 12. I have an opportunity to take some of my AVCHD (Sony Z7U) and MOV (Canon 60D) files and provide them for sale for stock video use.
    For general use what should I encode them as to be used cross platforms? Mp4? And then what would be the exact setting for encoding these for others to use in their edit systems.
    I want to get the best quality out of my original video files?
    Thank you
    dw
    DW Video & Multimedia, LLC
    “Using Today’s Media To Market Your Business”
    John Rofrano replied 12 years, 4 months ago 2 Members · 5 Replies
  • John Rofrano
    April 14, 2014 at 3:36 pm
    [Duane Weed] “For general use what should I encode them as to be used cross platforms? Mp4? And then what would be the exact setting for encoding these for others to use in their edit systems.”
    If you are going to compete with stock footage companies I would look at the formats that they use. Most stock footage that I have purchased has used the Photo-JPEG codec in a QuickTime container. This is very high quality and any NLE on any platform can ingest it.
    Just make a custom QuickTime template in Vegas Pro and select Photo-JPEG as the video format and disable the audio.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Duane Weed
    April 14, 2014 at 4:37 pm
    Thank you John,
    I was looking at the rendering options and need some help.
    Under qucktime do I click on one of the options and go to customize template?
    Then set my HD Frame Size. 1920 X 1080 (which I believe is what the sony z7u is set for.)
    Then my frame rate – which is ntsc.
    Video format – Image Jpeg
    You mentioned to uncheck audio- What if some of the clips need the wild sound? What option should I use?
    Thanks again – this is so helpful.
    dw
  • John Rofrano
    April 15, 2014 at 10:46 am
    [Duane Weed] “Video format – Image Jpeg”
    Video format: Photo – JPEG
    [Duane Weed] “You mentioned to uncheck audio- What if some of the clips need the wild sound? What option should I use?”
    If you want to include audio, it should be Uncompresssed / 48,000 Hz/ 16 bit for best quality and compatibility.
    ~jr
  • Duane Weed
    April 15, 2014 at 5:23 pm
    thank you very much.
    I ran some tests last night – perfect.
    dw
  • John Rofrano
    April 15, 2014 at 5:40 pm
    [Duane Weed] “thank you very much. I ran some tests last night – perfect. “
    You’re welcome. I’m glad that worked out for you.
    ~jr
