Activity › Forums › Compression Techniques › Encoding an H.264 that’s 2765×768
  • Encoding an H.264 that’s 2765×768
    Posted by Andrew Saliga on March 5, 2012 at 11:01 pm
    Attempting to encode an H.264 (preferably in a MOV container) that’s 2765×768. I’m having difficulty getting an encoder to accept the res without it either crashing the app or defaulting to a res that’s divisible by 16.
    I’d prefer to encode with Main Concept or x264 encoder. I’ve tried FCP, Compressor, Squeeze, DV Kitchen and MPEG StreamClip.
    Any ideas or suggestions appreciated.
    Andrew Saliga
    I/O Specialist/Assistant Editor
    Steelehouse Productions
    http://www.steelehouse.com
    Andrew Saliga replied 14 years, 6 months ago 1 Member · 1 Reply
  • Andrew Saliga
    March 6, 2012 at 3:02 pm
    Thanks Sathish. I tried using FFMpegX with no luck. I need to learn to use the command line version.
    I didn’t realize that After Effects is now licensing the Main Concept H.264 encoder, so I was able to encode to it straight from AE, but in an MP4 container. It only adjusted the resolution by one pixel.
    Hopefully I’ll hear back from the venue today that that resolution and MP4 container work.
    Andrew Saliga
