Activity › Forums › Adobe Premiere Pro › Encoding Advice Needed
  • Encoding Advice Needed
    Posted by Clint Milner on February 27, 2009 at 11:11 am
    Hi All,
    Just a quick question…
    I’m diving head first into Blu-Ray authoring with AVCHD footage taken from my Panasonic HDC-HS9. I’m shooting in PAL and my camera is set to film at 1920x1080p (1080/25p).
    In order to get Premiere CS4 to work a bit better with this footage, I was told I should convert the AVCHD to MPEG-2 for Blu-Ray to ease the problems with playback that Premiere seems to have.
    I’m using Media Encoder and I can’t find a preset for my footage. I made the mistake of using the “HDTV 1080i 25 High Quality” and having it render all night, the end result is pretty horrible. Interlacing artifacts and halos around objects everywhere.
    I see the “HDTV 1080p 23.976 High Quality” and
    “HDTV 1080p 24 High Quality” settings, but am I right in saying that these are NTSC settings?
    Also, if I switch either of these presets to PAL, the fps switch to 25 and the field order is on Lower. Should I try this?
    Many many thanks, I know this is a bit long, but an answers would be great!
    Clint
    Ann Bens replied 17 years, 7 months ago 2 Members · 1 Reply
  • Ann Bens
    March 1, 2009 at 3:46 pm
    You cannot make a BR in progressive PAL, interlaced is the only option. Field order should be upper.
