Activity › Forums › Adobe After Effects › Encoding a XVID file in AE CS5
  • Encoding a XVID file in AE CS5
    Posted by Raul Bastos on February 15, 2011 at 1:44 pm
    Hi there,
    I always worked with AE CS4 in Windos XP 32 bits, but now im working with AE CS5 in Windows Vista 64bits.
    I used to encode my videos using the XVID codec because of the good quality + small file size, but on CS5 this option is missing…=(
    I´ve tried installing K-lite 64 bits pack, only the Xvid codec, but nothing seems to work…
    Could someone help me?
    Tomas Bio replied 15 years, 2 months ago 3 Members · 3 Replies
  • Raul Bastos
    February 15, 2011 at 4:28 pm
    Wow, i got it off already!lol
    Thanks for the reply and damn I´m dumb, im using Windows 7(dont know why I wrote Vista..haha)
    So, is there any onther way to render my videos in AE to keep quality/size or I really need to try another application?
    Thanks again.
  • John Tolliver
    April 13, 2011 at 5:27 pm
    Ok, so there are clearly issues with xvid and CS5. I have found a solution that keeps the program from freezing up while rendering out a single pass AVI (we use them when rendering short static videos).
    In the options for the xvid codec: There is a button for “other options”, under the encoding tab, you must uncheck “Display Encoding Status” When that is unchecked, our AE renders fine.
    John
  • Tomas Bio
    July 29, 2011 at 8:06 am
    Thank you!!! WORKS! “Display Encoding Status” turned off and renders fine!
