Activity › Forums › Adobe Encore DVD › ENCODING
  • ENCODING
    Posted by Willie Toth on October 12, 2005 at 2:45 pm
    I would like to know what is the the best setting to encode at … My shows run between 27 and 29 min … I have been using 2 pass 7mb VBR … Thanks … WILLIE
    Yucel Ybrpro replied 20 years, 11 months ago 4 Members · 7 Replies
  • 7 Replies
  • Hector Melendez
    October 12, 2005 at 4:10 pm
    I’m not an expert but I think if you select “automatic transcoding” the program chosse the optimal encoding setting to full-fill the disc.
    (project>properties palette or expand project window to see the encoding setting)
  • Willie Toth
    October 12, 2005 at 4:16 pm
    Hector,
    Thanks I know that, however one of the stations that broadcast my program has old equipment and I have ran into problems with the playback …
  • Hector Melendez
    October 12, 2005 at 4:54 pm
    Check my new post. Me too having problems with the playback. Maybe we can find out what causing this problems. I’m now burning another disc at 4mb 2 pass. Will let you know later what happen after this. But because your have a shorter prog. you can burn a 7mb maybe variable rate.
    Could a new DVD player work with the broadcast station? What kind of play problems?
  • Willie Toth
    October 12, 2005 at 5:18 pm
    Hector,
    I don’t burn out of Encore, what I do is write it as an Encore Image file and once that is done I right click on the file and change the file extension to a .iso, I then burn using Roxio … I was having so much trouble with burning out of Encore that when I heard someone on the forum talking about doing it this way I jumped on it … You might want to give it a try … When dealing with public access you get what you pay for and this station doesn’t even require a membership for your productions to be played … I do have a weekly spot and after 8 years of doing nothing but audio the video thing has been a nice change ……… WILLIE
  • Mike Cohen
    October 13, 2005 at 3:19 pm
    I never encode higher than 6 mb. Yes, definitely don’t let Encore auto encode. I always encode out of Premiere, that way you know how much space on a DVD you will take up.
  • Willie Toth
    October 13, 2005 at 3:33 pm
    Mike,
    Thanks for your input I will try it and see if it makes a differnce … I agree with you about encoding out of Pre Pro … W
  • Yucel Ybrpro
    October 16, 2005 at 8:33 pm
    Dear Willie
    Most TV stations broadcast on DVB format in europe. When we deliver any media to broadcasters , mostly encode on Mainconcept Pro with 6 mbps on constant value and progressive field. DVB is an mpeg format using Main Profile (@MM) nearlly 4 mbps .
    The result is perfect. No complians from broadcasters
    YBR Pro
    Digital Content Provider
