Activity Forums Compression Techniques Encoding 4:4:4 in h264/h265
  • Encoding 4:4:4 in h264/h265
    Posted by Jonas Jensen on December 1, 2016 at 2:05 pm
    I’ve been trying for a while now to find a good solution for making high-quality video files, for local playback, to display detailed motion graphics. Basically I end up with problems everywhere because of the sampling rate. Almost all available formats will deliver in 4:2:2 which is not good enough for my purposes.
    So as I understand it, 4:4:4 encoding should be possible in H264, but I can’t find a solution for doing it.
    Will FFmpeg do it? And if so, could someone point me in the direction of the correct command?
    Chris Oram replied 9 years, 8 months ago 3 Members · 3 Replies
  • Icaro Lobo
    December 13, 2016 at 11:36 pm
    I was looking for the same thing and tried several ffmpeg GUI. The only one I could render 4:4:4 h264 was myffmpeg.
  • Icaro Lobo
    December 13, 2016 at 11:40 pm
    Also this: https://www.youtube.com/watch?v=AGvryaRGSK0
    But it is command-line.
  • Chris Oram
    December 22, 2016 at 2:43 pm
    the x264 profile command for this in ffmpeg is fairly straight forward to implement off of CLI – it is;
    -profile:v high444
    You will of course need to set your bit rates max/min and presets as desired but this profile setting will output a h.264 at 4:4:4.
    -Chris Oram
    https://antiversal.com
    Technology, Design and Development for Moving Image Creators
