Activity › Forums › Adobe Encore DVD › Encoder_making a dvd
  • Encoder_making a dvd
    Posted by Heidi Perkins on April 12, 2015 at 1:13 am
    I have a Mac Pro with no dvd burner/player. I loaded my H264 clip into encoder- went to dvd-then to NTSC dv wide–it made 3 new files, .2v, wav, and a xmp.
    I then transferred them to another computer with a dvd burner. Placed the 3 files onto the dvd, and burned it. It won’t play on my tv dvd. What am I missing…something about authoring?
    HELP!!
    Heidi
    Heidi Perkins replied 11 years, 5 months ago 2 Members · 2 Replies
  • Jeff Pulera
    April 15, 2015 at 7:01 pm
    Hi Heidi,
    I had the same experience many years ago the first time I attempted to make a DVD – you can’t simply burn media to a DVD disc and have the DVD player see it as a “Video DVD”. It MUST be Authored, using Adobe Encore or similar software. This compiles everything and you end up with a “VIDEO_TS” folder on the disc, with .vob files and other stuff inside. Insert any DVD into a computer drive and OPEN it and see.
    And even knowing that, one cannot “copy” the VIDEO_TS folder from an existing DVD to their hard drive, and then BURN that to a DVD and expect that to work either. It will just be a “Data” disc and not an official DVD – the files must be written a specific way to the disc, some sort of pointer set that tells the disc reader “The is a VIDEO DVD”, rather than a DATA disc.
    If you have Adobe CC, you will be able to download and use Encore CS6 – https://helpx.adobe.com/encore/kb/encore-cs6-installed-cc.html
    Jeff Pulera
    Safe Harbor Computers
  • Heidi Perkins
    April 15, 2015 at 11:36 pm
    That is exactly what I did and it worked!!! I felt like I was missing something until I saw in my research a comment about “authoring” I then to the file I created in Encoder and processed it in Encore. Walla. I had my DVD.
    Heidi
