Activity Forums Adobe Media Encoder Encoder gamma (color/contrast shift?) …one more time with feeling!
  • Encoder gamma (color/contrast shift?) …one more time with feeling!
    Posted by Roman Privalov on December 31, 2016 at 1:24 am
    Screenshot speaks for himself!
    Just simply adding from AE to ME. Its’ darker …or more contrast …or gamma shifting…
    Tried everything:
    – nvidia DR 0-255 / 16-235
    – software / Mercure CUDA engine
    – in AE working space is “none”
    – in ME any codec, any settings
    Adobe Media Encoder just makes a different look to the image!
    Any suggestions?
    But don’t tell me that h264 changes colors… and some player issues… CAUSE IT’S OBVIOUSLY NOT THE CASE!
    ME renders that way! His own different way))
    Roman Privalov replied 9 years, 6 months ago 2 Members · 2 Replies
  • Chris Wright
    December 31, 2016 at 6:53 am
    that’s one dilly of a problem! have you tried rendering from AE directly?
    AE also has an effect called color profile converter. have you tried adding an adjustment layer and placing that effect over the top. input rec. 709 , output-16-235. it would lighten AE and then media encoder might re-adjust back.
  • Roman Privalov
    February 22, 2017 at 11:29 pm
    btw, it’s a PC platform, so no core QT engine)
    Ok)
    I actually found out the reason for this particular case of mine – contrasty looks. But I wanted at least someone to reply something first))
    My problem lies here:
    Project settings – Color settings – Working space
    I was never used any working space in my projects. Never. But one day YouTube enabled support for HDR videos. So I’ve read the official requirements for the videos to be recognisable as HDR by YouTube service. Something about color space… REC.2020 for example. And here where I’ve messed my project:
    1. I’ve changed project Working Space from NONE to REC.2020 and before inactive “Compensate for Scene-reffered Profiles” option became active and checked.
    2. I’ve played around with new REC.2020 project state, but decided to revert to default NONE. So I went back to that menu, changed project Working Space from REC.2020 to NONE and active “Compensate for Scene-reffered Profiles” option became inactive and but still checked.
    And after that I’ve began to get in AME that contrasty looks in this particular project.
    But my thinking was – it is something about Working Space menu, but I’ve reverted everything like it was before and “Compensate for Scene-reffered Profiles” is greyed out and it doesn’t matter if it checked or not!! …I was wrong )))
    Yes, it’s greyed out BUT IT IS CHECKED!
    3. For some stupid “what da hell” I went once again to project settings and changed Working Space from NONE to REC.2020, “Compensate for Scene-reffered Profiles” became active, I UNCHECKED it and set Working Space to NONE again.
    AME started to render exact same looks like I see it in AE.
    and here’s the tricky part. After that victory, I decided to make the same “uncheck operation” in my other project where I DIDN’T touch Working Space option ever before. So “Compensate for Scene-reffered Profiles” option was greyed out and checked. I’ve made it active and unchecked it …and I received just the opposite effect in AME. When before it rendered proper image, after “uncheck operation” it began to render contrasty )))
    So, if shorter))
    If I make any changes in Working Space option then “Compensate for Scene-reffered Profiles” option should be unchecked even if it greyed out (inactive).
    So stupid and unscientific ))) and probably not strictly true method, but for my AE it works!
