Activity › Forums › Adobe Premiere Pro › encoded mpeg2 stutters when played – any thoughts
  • encoded mpeg2 stutters when played – any thoughts
    Posted by Preston Brown on December 17, 2007 at 2:40 am
    Encoding timeline mix of video, audio, and pictures using Premiere Pro 2.0’s adobe media encoder with following settings:
    mpeg2; preset 1080 24p 15 MBps VBR.
    Resulting encoded video stutters and is slowed when played back using various players (windows media player 11, intervideo winDVD 5). I am wondering if anyone knows why. Possibly I need a different codec or maybe I have a glitch?
    I am attempting to use this setting because it produces the highest quality playback as compared to mpeg2-DVD, SVCD, or other mpeg2 settings such as NTSC generic. I would be open to using other encoding settings if I can get similar quality and I cant fix my problem.
    Thanks for any thoughts
    Jeff Kosmicki replied 18 years, 9 months ago 3 Members · 2 Replies
  • Mike Velte
    December 17, 2007 at 11:37 am
    Most computers could not decompress and playback smoothly any codec that compresses 1920 x 1080 to such a high degree. Less compression (higher bitrate) cause playback issues without at least a SATA Raid.
    You really need much less resolution for local playback or author to a Blue Ray disc for playback on a Blue Ray player.
    If for local playback, what is the resolution of your screen?
  • Jeff Kosmicki
    December 18, 2007 at 3:33 pm
    If you don’t have one already, try a PCIe video card with HD playback ability, that should solve your problem. It’s usually a combination of decompression and updating such a large area of the screen quickly that causes systems to drop frames. Just about any recent ATI or Nvidia card has on-board processing to handle this.
    I have two identical systems, one has a very low-end gamming Nvidia GPU (about $50), and one with a Matrox Parehlia card (about $350). The system with the Nvidia can play WMV HD clips all day without ever dropping a frame, the Parehlia can’t go for more then a few seconds before dropping frames.
    Jeff Kosmicki
    http://www.toyraygun.net
