Activity › Forums › Adobe Media Encoder › Encode settings with a max frame size
  • Encode settings with a max frame size
    Posted by Xavier Paredes on May 26, 2020 at 8:42 pm
    Dear forum members,
    Is there a way to create a preset in Adobe Media Encoder that will allow you to define maximum width and height frame dimensions?
    I have 1112 short videos all with crazy different frame sizes. For example:
    208 x 192
    520 x 708
    1016 x 688
    … and everything in between!
    I would like to be able to encode these videos so that the resulting videos do not go over a max width or height BUT at the same time maintain their original aspect ratio.
    For instance, I would set a max width of 768 and a max height of 640. Using the same example frame sizes above, the following would happen when encoded:
    208 x 192 (this video would stay the same size because neither width nor height go over the max values in the preset)
    520 x 708 (this video would be scaled down to 467 x 640 because the height is greater than the max height allowed in the preset)
    1016 x 688 (this video would be scaled down to 768 x 519 because the width is greater than the max height allowed in the preset)
    Sorry for the long post but I have tried my best to explain what I need.
    Thank you!
    PS: I do know that I can do this by changing the frame dimensions in each comp in After Effects but I would like to not do that if possible.
    Xavier
    Xavier Paredes replied 6 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
