Activity Forums Adobe Premiere Pro Encode freezes at 39%
  • Encode freezes at 39%
    Posted by Tony Hearst on March 17, 2014 at 1:44 pm
    Attempting to export project, WMV, NTSC DV Widescreen Video 9 Codec. Export freezes at 39%, sequence plays fine, no glitches or sync issues. What gives?
    Tim Kolb replied 12 years, 6 months ago 3 Members · 2 Replies
  • Jeff Pulera
    March 17, 2014 at 5:44 pm
    Hi Tony,
    Check for a one-frame gap in the timeline, I’ve seen that cause export issues
    Jeff Pulera
    Safe Harbor Computers
  • Tim Kolb
    March 17, 2014 at 9:27 pm
    It’s not the percentage, it’s some particular point in the timeline.
    In cases where I have issues like this, I will create a shorter range and export, and I’ll keep shortening the range and “zero in” on the spot if there is nothing else that’s immediately obvious to you.
    I’d start by exporting the second half of the timeline…if that works, keep backing up the starting point until it falls over.
    It may be a strange spot in a source clip that plays back well enough but has a slight issue with a complete decode…it’s hard to say.
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
