Activity Forums DaVinci Resolve Enabling video field processing causes aliasing in downscaled clips
  • Enabling video field processing causes aliasing in downscaled clips
    Posted by Joe Bender on July 21, 2018 at 1:12 am
    Hi all,
    Getting ready to conform/color a new project in Resolve, which includes a lot of downscaled 4K footage to a 1080p timeline and a few interlaced archival clips. So in order to correctly deinterlace the archival clips, I turned on video field processing. That works correctly for the interlaced archive, but it also creates serious aliasing in the downsampled 4K clips. This is not just a display artifact, it is present in the rendered footage. Now, I can handle the interlaced archive in a separate project, but for simplicity’s sake I’d like to do the whole film in one project if possible. Is this something that you’ve encountered, and is there a workaround?
    I am using:
    Resolve 15b6
    iMac 5k 4.2gHz 40GB RAM
    RX 580 8GB
    eGPU RX580 8GB
    macOS 10.13.6
    Many thanks,
    Joe
    Massimo Alberto croce replied 8 years, 1 month ago 2 Members · 5 Replies
  • Massimo Alberto croce
    July 23, 2018 at 8:12 pm
    You turned on video field processing on project setting? For progressive output this setting must turned off.
    Massimo Alberto Croce
    Video Editor, Colorist, Pro Tools Editor
    massimoalberto.croce@gmail.com
  • Joe Bender
    July 23, 2018 at 8:36 pm
    Hi Massimo, thanks for your reply.
    I enabled video field processing because as far as I could tell that was the only way to get Resolve to deinterlace the archival footage correctly. Is there another method that I should use instead? If there’s something else I missed there please enlighten me.
    Thanks again,
    Joe
    July 23, 2018 at 9:20 pm
    deinterlace is a clip setting, leave video field processing off and tick “enable deinterlace” on clip attributes for interlaced footage ,
    this function is only available in Davinci Resolve Studio.
  • Joe Bender
    July 23, 2018 at 9:52 pm
    Yes, that’s the nominal workflow, but when following that Resolve Studio was not deinterlacing my clips, just making them ‘wavy’, misinterpreting the fields or something. Resolve only correctly deinterlaced the clips when I turned video field processing on. I’ll try again to verify, but that’s the behavior I was experiencing.
    July 24, 2018 at 12:08 pm
    remember that you are using a beta software, have you tried with DR 14?
