Activity Forums Adobe After Effects Enable Time Mapping – n=3 n*time?!?
  • Enable Time Mapping – n=3 n*time?!?
    Posted by David Del on September 19, 2007 at 6:57 pm
    I was just working through Dan Ebbert’s expression and it doesn’t seem to work for me – actually it looks like it speeds up the clip.
    https://forums.creativecow.net/thread/2/914977
    Here is the expression :
    n = 3;
    n*time
    I want to create a semi-stop motion, but without the fluidness. So from a video clip I want to take only let’s say every 2 seconds (an image) and then the next 2 seconds (an image) etc. I hope this makes sense. I also hope I can determine and change the time between images.
    Do I need to render it out as still frames? I have an audio track that goes along with it, so I want to keep the clip the same length as the audio…any ideas what I am doing wrong?
    I am also emailing Dan personally and hope he has a solution.
    David
    David Del replied 18 years, 11 months ago 17,657 Members · 2 Replies
  • David Del
    September 19, 2007 at 9:59 pm
    After talking to Dan over email, I decided to use Posterize Time, which seems to work quite well (thanks Dan!), but I am finding strange happenings in After effects with Posterize time – first, but masks are no longer working. And after using the Colourama and Scribble Effect, my clips are becoming multi-coloured when I drop the Posterize Effect on them.
    Anyone know what is going on?
  • David Del
    September 19, 2007 at 10:30 pm
    Ok, I figured it out. I had to pre-compose the layer with Posterize on it and then work with the other comp for the mask and other effects to work right.
