Activity › Forums › Apple Final Cut Pro Legacy › Enable RT extreme for Photo JPG 75% at HD sizes
Posted by David Slater on May 27, 2006 at 2:29 amI have 5.1.1 and I tried to find the enabler file to allow PhotoJPG 75% at HD sizes to be RT in FCP as per https://forums.creativecow.net/cgi-bin/new_read_post.cgi?univpostid=886185&forumid=8&postid=886329&pview=t
BUT
I can’t find that file anymore
anyone know where it isDAVE at Movies Rock in Toronto
Sean Oneil replied 20 years, 3 months ago 2 Members · 5 Replies -
Sean Oneil
May 27, 2006 at 6:30 pmThey moved the location of “RT Enabler” with the release of 5.1. It’s still in the Contents of the “Final Cut Pro.app” somewhere and the hack does still work. I forget where it’s exact location is. Use Spotlight to seach the Contents folder to find it.
Sean
David Slater
May 28, 2006 at 6:49 amused spotlight
only one I can find it the AJA LHe enabler in the Application support plugin folderany more ideas?
Sean Oneil
May 30, 2006 at 6:51 amTrust me, it’s there. You have to tell Spotlight to specifically search within the “Final Cut Pro.app/Contents” folder. Simply using the Magnifying Glass in the top right of the screen will not search within application files (which is where this is).
Open up the FCP/Contents folder in a Finder window. Then use the search box in that specific Finder window. Now you’ll see the advanced Spotlight options. Make sure to choose the “Contents” folder as your search area.
Sean
David Slater
May 30, 2006 at 10:52 pmOH I found it (sorry I didn’t get back to ya)
did the editafter a couple of clips I was running into no end of trouble
long frames where EVERYWHERE over 1050 1.25 frames 600 2.5’s and 6 3.75’s (plus it would take forever to capture as it would start to capture then go back and start again)anyway
now using DVCPRO HD compressor (doesn’t look as good but there are no long frames at least)Thanks anyway man
Sean Oneil
June 1, 2006 at 5:34 amVery strange. Haven’t seen this or heard about it yet. Sorry you had problems.
