Activity Forums Blackmagic Design Enable Legacy QT Playout – Question
  • Enable Legacy QT Playout – Question
    Posted by Sven Hanten on September 29, 2005 at 3:16 pm
    I have a Question regarding to “Enable Legacy QT Playout”.
    On one System (OS X 10.3.8) I have a Decklink HD Pro Dual Link there I can turn on and off the feature “Enable Legacy QT Playout”.
    On the second system (OS X 10.4.1)I have a normal Decklink HD Card there the feature “Enable Legacy QT Playout” is greyed out and I cannot enable or disable it.
    The problem is, that I use Shake on this System and Quicktimefiles are shown black within Shake when the “Enable Legacy QT Playout” is enabled. On the first System I just could simply disable disable the QT feature and everything works, now I don’t have the possibility. The only thing I can do is the “force 8Bit button” in Shake, but then I loose image information with 10Bit files.
    When I uninstall the Blackmagic driver, everything works fine.
    Any suggestions?
    Sven
    Phil replied 20 years, 11 months ago 2 Members · 1 Reply
  • Phil
    September 29, 2005 at 7:44 pm
    Same problem here.
