Activity › Forums › Adobe After Effects › emitter to follow orbital null child
  • emitter to follow orbital null child
    Posted by Will Brenner on October 17, 2019 at 2:35 am
    I have a null in the center of a comp. I have the null rotating in 3d space. Then I parented another null (3d layer) to the rotating layer, so that it orbits the other null.
    I want to use the position of the orbiting null to drive the emitter position of an CC particle world.
    Is this possible and how would I do it?
    Thank you!
    John Williams replied 6 years, 11 months ago 2 Members · 1 Reply
  • John Williams
    October 17, 2019 at 10:06 am
    CC Particle Systems is a simulated 3D effect, which means it doesn’t actually use true 3D Z space.
    CC Particle World gives you Z space co-ordinates so you will need to use that one.
    Here’s a link that’ll explain the expression method more clearly than I can right now.
    https://youtu.be/FVrgLK6Zovw
    John Williams
    Soho Editors
