Activity Forums Boris FX Particle Illusion Emitter size bigger by pulling the sides cant get it to work anymore
  • Emitter size bigger by pulling the sides cant get it to work anymore
    Posted by Tony Hampton on May 12, 2014 at 11:12 pm
    hi
    in the older version i could pull a Emitter size bigger on the sides
    but with the update has that changed ? and my Emitters when i put them on screen they are
    really smaller , not sure if i changed something or not
    it as been a bit along time that i have used pl
    thank you for your time
    Alan Lorence replied 12 years, 4 months ago 2 Members · 1 Reply
  • Alan Lorence
    May 21, 2014 at 8:32 pm
    Tony — sorry I didn’t see this earlier!
    You’ve never been able to make the particles bigger by using any on-screen controls, but maybe you mean an ellipse or area emitter? You can still change the radius and/or width/height by grabbing the emitter handle while in “select” mode.
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
    http://www.genarts.com
    http://www.wondertouch.com
