Activity Forums Boris FX Particle Illusion Emitter question for Tom or Alan
  • Emitter question for Tom or Alan
    Posted by Bob Moyer on April 11, 2012 at 2:19 pm
    Win7/pI 3.0.4.3/emitter library 12_01.il3
    I have added HUD Air 2 Air 2 to my stage (720 x 480) and reduced the size to fit on my stage. The number portion of the two emitters “Angle” and “Alt” continue to scroll past the top of the emitter and do not disappear until they scroll off the top of the stage. In other words, how can I get them to stay contained within their respective green boxes. Hope that is clear. Thank you.
    Bob
    Laura Newell replied 14 years, 4 months ago 3 Members · 3 Replies
  • Alan Lorence
    April 11, 2012 at 2:24 pm
    How did you reduce the size to fit your project? If you used the “zoom” parameter it should work fine. If you used “size” that’s the mistake. Size just changes the size of particles, while “zoom” changes size and velocity. Zoom is equivalent to “scale” in most apps, while “size” is just particle size.
    Hope that helps.
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
    http://www.genarts.com
    http://www.wondertouch.com
  • Bob Moyer
    April 11, 2012 at 2:33 pm
    Boy! Talk about quick response time…I am impressed. You guessed correct I used the size parameter and the zoom works much better. Thanks again.
    Bob
  • Laura Newell
    April 12, 2012 at 4:03 pm
    hi not sure if right place but im trying 2 create effects,successfull till render,effects not rendering i did get new pc,with ati 6200 hd something card,i tryed tweeking seeting as no effects will render nothing,trying reinstall any other suggestions
