Activity Forums Boris FX Particle Illusion Emitter libraries
  • Emitter libraries
    Posted by Joe Morgan on January 24, 2013 at 4:44 pm
    It would seem to me that the best thing to do with emitter libraries would be to look back at the
    BEST EMITTERS and convert them into in HD Format.
    I personally am not very good at creating my own emitters. I only like working with full HD. I don’t care much for working with low-resolution stuff.
    I’m not sure how possible that is with 32-bit particle illusion.
    Simple handheld full HD cameras are becoming so inexpensive and common that I don’t see how anything low resolution has much of a shelf life left.
    I am also curious about the 64-bit question. I would love to step up to a 64-bit particle illusion.
    Alan Lorence replied 13 years, 7 months ago 5 Members · 4 Replies
  • Michael Bey
    January 28, 2013 at 7:46 pm
    That would be great. It seems like this product has fell to the wayside. No new libraries, no upgrade to 3D, etc. I love this product but am becomming concerned one day there will be no support whatsoever. Kind of sad. Such a great product.
  • Erik Gertscher
    February 3, 2013 at 2:07 am
    is it possible to convert old emitters to hd in the program. and if yes how ?
    and can i convert all old emitters ?
  • Craig Cooper
    February 12, 2013 at 1:11 pm
    I produce 1280×720 with PI all the time. The emitters aren’t Standard Def or High def. Just set your project what ever size you need.
  • Alan Lorence
    February 12, 2013 at 10:24 pm
    What it really comes down to is what the particle images will be used for. If you’re doing sparkles all the time that render as 10×10 pixels, even in a 1080 project, using larger images won’t gain you anything.
    If however you want those particles to be large, like some of the more graphic or textural emitters in the Pro Emitter sets — something that is going to take up a significant portion of the frame — then you’ll want larger particle images.
    But using large images for small particles is not good either. pI currently does not support MIP mapping, so cramming a big image onto a tiny particle doesn’t look as good as it could. Plus it wastes texture memory like crazy.
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
    http://www.genarts.com
    http://www.wondertouch.com
