Activity Forums Boris FX Particle Illusion Emitter Effects Behind A Subject?
  • Emitter Effects Behind A Subject?
    Posted by Ray Jender on August 19, 2009 at 7:28 pm
    New user playing around with PI.
    How do you use an emitter and have it’s effects go behind a subject on a video?
    For instance in the ballerina example, the sparkles can be seen in front of her,
    but also, they are behind her.
    Ray
    Rob Dahl replied 17 years ago 2 Members · 1 Reply
  • Rob Dahl
    August 19, 2009 at 8:56 pm
    Well that would depend on your footage and scene setup.
    You could:
    Set up a blocker that is animated like the dancer in PI.
    You could rotoscope the dancer and place the effect behind the roto’s layer.
    If the dancer is filmed on a chromascreen, use layers to control the effect… similar to rotoscoping.
    Other please weigh in… if there is a better route to take.
    Rob Dahl
    Transparent Alchemy
    Boulder City, NV 89005
    http://www.transparentalchemy.com
