Activity Forums Apple Motion Emitter contained within object
  • Emitter contained within object
    Posted by Ed Bates on June 6, 2012 at 2:35 pm
    Hello,
    I am trying to contain some objects from an emitter within a box, etc. I want them to bounce around within a box, circle, or other polygon. I have tried using the repel behaviors, etc… not working for me. Any ideas? (Using Motion 5)
    Ed
    Aj Robinson replied 14 years, 3 months ago 3 Members · 5 Replies
  • Mark Spencer
    June 6, 2012 at 2:41 pm
    Use the Edge Collision behavior – in the Simulations category.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Ed Bates
    June 6, 2012 at 2:53 pm
    Mark..Thanks,
    I tried that, but unless I’m missing something, I’m limited to a box. I’d like to have this work within an irregularly shaped object.
    Ed
  • Mark Spencer
    June 6, 2012 at 3:32 pm
    That’s all you can do
    Mark Spencer
  • Ed Bates
    June 6, 2012 at 3:41 pm
    I applied a mask to the group containing the emitter and edge collision behavior. It isn’t exactly what I wanted, but close enough. Thanks for you responses.
    Ed
  • Aj Robinson
    June 15, 2012 at 8:29 pm
    Ed Bates,
    I know your frustration. I had the same problem. As it turns out, Edge Collision is what you need to use, but you just need to know how. Here is a link to a video I made that the particles bounce off the wall.
    https://www.youtube.com/watch?v=96moYANG5jw&feature=youtube_gdata
    I cannot tell exactly tell you what I did. Here is a picture of the HUD.
    I’m aslo going to give you the link to the project I made. Click on the link and download my Motion project. Once open under the emitter group, you’ll find the Edge Collision effect applied.
    Play around with the settings I used. Here’s the link, https://www.dropbox.com/sh/drpmlmoq932z3df/Babp7FBd4R/Shutter%20Wall Download all the media as well as the Motion project. You should be able to see how the particles bounce off the wall I made.
    I hope this really helped,
    AJ
