Activity Forums DaVinci Resolve Emergency situation on DaVinci
  • Emergency situation on DaVinci
    Posted by Sascha Engel on August 16, 2013 at 12:24 pm
    Hallo Everybody,
    I would really appreciate some advice on two issues, since I face a tight deadline:
    1.) I just hooked up my new BlackMagic Mini monitor over Thunderbolt, and after that it went all weird. When I imported my XML, I get right away the warning: “Error occured while Decoding Audio Track using QTDecoder”, and after that all thumbnails go black and I just see black in the viewr of the current clip.
    2.) So, I made a new project and then it got worse: When I import, the XML, Davinci tells me it does not find the files, and when I want to go to the folder where the Media is stored, Davinci sees the folder as empty, even though all the clips are inside.
    Please, help!
    Thanx a lot.
    Greetings,
    Sascha Engel
    TIME BANDITZ Productions
    http://www.youtube.com/taikang
    Sascha Engel replied 13 years, 1 month ago 3 Members · 4 Replies
  • Eric Johnson
    August 16, 2013 at 3:48 pm
    What is your edit/source media?
    eric b johnson
    online editor | colorist | workflow
    https://vimeo.com/39073239
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Sascha Engel
    August 16, 2013 at 4:18 pm
    Material was shot on C300, ingested into FCP7 as ProRes HQ, then output an XML and imported into DaVinci.
    I know, made a whole new Database and simplified the sound to 2 tracks.
    Seems to be ok now.
    Should I grade this footage with or without a LUT?
    Never really got into LUTs, because they gave me usually a too contrasted image.
    The footage was shot in C Log.will it be ok to grade directly?
    Thanx.
    Sascha Engel
  • Andi Winter
    August 16, 2013 at 6:24 pm
    hi sascha,
    of course! in my opinion LUTs are good for preview versions, eg dailies to edit with.
    i never use a lut in grading. after all it is kina like a pregrade, you can use it if you like
    the outcome, or don’t use it.
    if you are planning to use a lut it is usually a good idea to have a “prenode” in which
    you can alter the image contrastwise, so the lut doesn’t “throw away” some of your
    recorded detail.
  • Sascha Engel
    August 16, 2013 at 9:46 pm
    Thanx Andy,
    You just confirmed what my stomach told me already.
    Do you by chance know a good LUT to download for the C Log footage of the C300?
    I found several, contradicting links.
    Thanx.
    Sascha Engel
