Activity Forums Adobe Premiere Pro Emergency problem! Wrong frame rates … 29.97 -> 23.976
  • Emergency problem! Wrong frame rates … 29.97 -> 23.976
    Posted by Kris Koster on February 22, 2011 at 2:35 pm
    Hi folks,
    I have a bit of an emergency on my hands with a project that has to be in today.
    I filmed a video on the Canon 5D mark II at 29.97fps (30p).
    Nearly all my clips are therefore 29.97fps.
    In Premiere Pro CS5 I created a 23.976 timeline and interpreted all my footage in the project window to use the 23.976 frame rate. Because I don’t have to worry about sound on this project, so I thought it would give my visual footage a nice slow motion movement (80% slow down).
    My eyes might be deceiving me, but the rendered output doesn’t look as smooth as it should and I’m thinking it could be because of what I did with the frame rates.
    So I created a new sequence at 29.97 and re-interpreted all the clips back to 29.97. However, the edit is now not right because re-interpreting the clips have changed where the cuts are.
    Is there any way to fix this mess quickly? I don’t care anymore if it’s 23.976 (preferred), or back to 29.97 – I just need the rendered output to be smooth and get this out the door.
    Thank you for any offer of remedy!!
    Vince Becquiot replied 15 years, 6 months ago 2 Members · 2 Replies
  • Vince Becquiot
    February 22, 2011 at 9:19 pm
    Hi Kris,
    Unfortunately, it’s not that simple, frames that are removed are creating that jitter. You’ll probably want to avoid 24p anyway, it has always been a bit of a gimmick anyway, it does not create a film look…
    But I’ll get right to the answer.
    Create a new 29.97 sequence, with the same number of video and audio (mono/stereo) tracks, then copy and paste the clips from your previous sequence to the new one. Re-interpret all your footage at 29.97, you should be good to go.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Vince Becquiot
    February 22, 2011 at 9:22 pm
    BTW, I missed the 80% slow down part, do you mean 20%, or are you slowing down the footage further?
    Vince Becquiot
    Kaptis Studios
