Activity Forums Adobe Premiere Pro EMERGENCY!!! Premiere damaged project!
  • EMERGENCY!!! Premiere damaged project!
    Posted by Alec Iselin on April 9, 2014 at 8:39 pm
    I opened my premiere project, and accidentally bumped the usb connection which disconnected my hard drive. After I reconnected it and tried to open the project back up, it told me it wanted to reset the scratch folder to my documents. I said continue, and it told me the file couldn’t be opened because it was damaged. Same with the auto saves, and when I try to import it into another premiere project.
    Please help me figure this out. I was just about to put the final audio mix into my film when this happened. I can’t afford for it to be damaged now.
    Thank you
    Tim Kolb replied 12 years, 5 months ago 5 Members · 4 Replies
  • Vince Becquiot
    April 9, 2014 at 8:41 pm
    Hi Alec,
    At this point your only option may be an auto-save or a backup.
    If it didn’t save the entire project, they may be little you can do with the current file.
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • Angelo Lorenzo
    April 9, 2014 at 8:42 pm
    Disk utility, or disk warrior if you’re on Mac.
    Premiere Pro CC? Unfortunately, they use a compressed file format so if it’s damaged…. there is little to no success to recover it.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Al Jensen
    April 9, 2014 at 8:49 pm
    If you’re in Windows and you’ve ever exported a test or anything, you can type %temp% into the run box and there should be a ton of project files, one of which should be YourProjectName_1.prproj. The higher the number, the more recent the version. Hope this helps!
  • Tim Kolb
    April 15, 2014 at 10:43 pm
    If you had auto-save running, you should have a folder of saved projects…most likely next to the original project in the original directory.
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
