Activity › Forums › Maxon Cinema 4D › Emergency: How do I make segments stay connected to each other while Extruding?
  • Emergency: How do I make segments stay connected to each other while Extruding?
    Posted by Bernard Santos on July 6, 2016 at 1:48 am
    Hi everyone,
    I’m still pretty new to 3D modelling with C4D, and I’ve seen this fixed before, I just can’t remember what to do first before I extrude. The piece I’m working on is about done, but it is due on Friday, and this base is the only thing I need left to do.
    It would be great to get it figured out asap.
    Thanks a bunch in advance everyone!!
    10268_capture32.png.zip
    Bernard Santos replied 10 years, 2 months ago 3 Members · 6 Replies
  • Brian Jones
    July 6, 2016 at 3:55 am
    make sure Preserve Groups is checked in the Extrude Options
  • Bernard Santos
    July 6, 2016 at 4:20 am
    That’s thing, it is.
    Even tried it with another Premitive with a few subdivisions added, same issue.
    Thanks for the tip though.
  • Brian Jones
    July 6, 2016 at 4:29 am
    it works, can you post an example file where the extrude doesn’t work?
  • Bernard Santos
    July 6, 2016 at 4:59 am
    Here you go. I made a copy so you can try it out.
    10270_extrudenotworkingright.c4d.zip
  • Adam Trachtenberg
    July 6, 2016 at 12:58 pm
    You need to set the minimum angle in the extrude tool to a positive number, like 89.
  • Bernard Santos
    July 6, 2016 at 4:50 pm
    Hi Adam,
    I’ve tried that as well, and it’s still not connected. I need to make an Inner Extrude after the extrude, and it’s creating a weird split at the corner of the top faces that are selected.
    Thanks Adam!
